Page 2 of 8 FirstFirst 1234 ... LastLast
    i quite like the mixed slat idea!...im going to use 100x50x6 angle to support the slats which will be spaced 20mm away from the main frame so i can eventualy turn it into a water table with down draft air extraction...im planning to use magnets to hold the torch to the z axis so if it hits anything it will break away.............
    had an evening of drilling tonight..managed to secure the first linear rail..then started fabricating the gantry
Name:	IMAG0212 - Copy.jpg
ID:	19699Click image for larger version.
ID:	19700Click image for larger version.
ID:	19701Click image for larger version.
ID:	19702Click image for larger version.
    managed to get the gantry mocked up today
ID:	19707Click image for larger version.
ID:	19708Click image for larger version.
ID:	19709Click image for larger version.
ID:	19710Click image for larger version.
    Looking smart.
    Looking smart.
    thanks lee.
    iv got a bit of time,so hopefully this is the last big push to getting it finished
  6. #16
    only managed a few hours in the shed today...managed to mount the linear rails to the x axis gantry....lots of m5 tapping
ID:	19726Click image for larger version.
ID:	19727Click image for larger version.
  7. The Following User Says Thank You to warwick For This Useful Post:
  8. #17
    iv managed to get the x axis painted..and the z axis pretty much finished. iv gone for two short lengths of 16mm linear rail and and old piece of ball screw..
ID:	19835Click image for larger version.
ID:	19837Click image for larger version.
ID:	19838Click image for larger version.
  9. #18
    reduction box ..
    iv ordered 15mm silver steel to build the shafts,15mm pillow block bearings (look very cheap) and the t5 pulleys are coming pre bored and grub screwed, by doing this hopefully the only bit of engineering will be to bore the 24t rack gear...
  10. #19
    iv managed to build the x axis reduction box today..iv mounted the stepper upside down, im not sure i really like it like this,my plan is to make a cover to hide the motors and wiring...Click image for larger version.
ID:	19936Click image for larger version.
ID:	19937Click image for larger version.
ID:	19938Click image for larger version.
ID:	19939Click image for larger version.
  11. #20
    Looks really good. What is your plan for tensioning your pinion gear into your gear rack?
  1. Have you built your own CNC plasma table ?
    By adscnc in forum Opportunities Available & Sought
    Last Post: 15-09-2016, 02:13 PM
  2. Plasma table 4x4 kit and electronics
    By whensparksfly in forum Items Wanted
    Last Post: 27-02-2016, 01:37 PM
  3. 10' x 5' Plasma table design
    By Kerryfisher in forum Plasma Table Machines
    Last Post: 20-02-2013, 09:28 AM
  4. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
