    ned's Avatar
    Lives in dublin, Ireland. Last Activity: 18-12-2023 Has been a member for 8-9 years. Has a total post count of 23. Received thanks 1 times, giving thanks to others 0 times.
    Warwick you there? hows it going man? The extra bit on your x axis, is that for a rotary axis? I want one!
    hi ned, sorry i havent been about much....tables working fine,,,cutting with it most evenings.....yes the extra piece on my x axis is indeed for a rotory ...i havent really thought about the scribe or the rotory axis yet.......i get email notifications if you post or message,,,,
    ned's Avatar
    aright man ) well done, good for you. I'm going to do the same, building the x axis out for a rotary axis. I want to be able to cut tube neatly. Lots of potential there.
    i bought an 8x4 router table, and repaired it, stared at it good and proper, and now im feeling confident enough to start a fresh build and sell this one. I might hit you up for the gantry plates, going to use rack and pinion. can you cut alu? will pay of course. How do you even buy alu, its expensive as she**e! Yah rotary axis man, fun fun.
    hi chaps, thought id post some of the things weve been cutting...im just starting a stretch on our narrowboat so between getting the plasma business going,keeping a roof over our heads and doing the boat it hasnt left much time for anything else....please dont think iv used to the forum to build my machine and im not giving anything back...
ID:	21844Click image for larger version.
ID:	21845Click image for larger version.
ID:	21846Click image for larger version.
ID:	21847Click image for larger version.
    done countless brackets for different jobs...
ID:	21849Click image for larger version.
    I like it. What sort of tolerance would you have through a 3mm steel plate? Do you do mail order?
    hi robin, when i first set the table up it was doing .5mm tolerance, i havent checked it sinse as iv been doing the above sort of stuff and fabricating type brackets that dont require an engineering type toleronse...if you need anything cutting please get in touch....i stock 2mm 3mm 5mm 10mm mild steel plate...iv done a small amount in stainless steel and havent tried aluminium yet....
    iv found when i was building the gear lamp that some of the holes were very tight for the bolts to go through and i had a devil of a job drilling them out as i think that the hole being cooled with an air jet hardened the metal??
  1. Have you built your own CNC plasma table ?
    By adscnc in forum Opportunities Available & Sought
    Last Post: 15-09-2016, 02:13 PM
  2. Plasma table 4x4 kit and electronics
    By whensparksfly in forum Items Wanted
    Last Post: 27-02-2016, 01:37 PM
  3. 10' x 5' Plasma table design
    By Kerryfisher in forum Plasma Table Machines
    Last Post: 20-02-2013, 09:28 AM
  4. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
