    Would 3 of these be the sort of thing you are looking for ? You might only need 1 if the motors are all at the same speed.
    http://www.ebay.co.uk/itm/Stepper-mo...YAAOSwIgNXlrJf
    You would still need some cheap drivers and a power supply though.
    Rob
    Rob
    Yeah Rob that's what I was thinking, but I don't know if I can run all three off a single 3A supply or I'll need separate ones per motor. I'll post results as soon as I have a test ready.
    I mean what could possible go wrong ?? lol :)
    Ralph Waldo Emerson
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    It'll depend on how well matched the motors are, and how much load each one is under.
    If they're all identical motors with similar load (and/or a good safety margin), then it shouldn't be a problem. All you can do is try it, as the worst that's likely to happen is motors stall, or one heats up.
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Is your question about whether a single 3A supply would be enough? If you are not looking for much torque from the motors, then most drivers will have a "max motor current" setting which you could wind down to, say, 1A. I'm assuming single power supply/multiple drivers here, of course. Problem is greater if you are using a switch-mode power supply as these often have a "hard" current limit at their max rating so can effectively switch off just when you need most current at peak load. Old-fashioned linear power supplies are much more forgiving of peak loads. Or wind down max motor current a bit more, or use a bigger or multiple power supplies.
    Neale, my understanding is fivetide wants the 3 motors to run from a single driver..
    That's true .. I would like to manually vary the speed of all three motors simultaneously. Toque maybe a factor in the future
    There are 40A versions of the Motor controllers for not much money. My understanding of power supply is limited, if I attach 3 motors that draw 2A's each onto a 40A supply will the motors only draw 2A's of the 40 or will the power supply push 13A's to each motor.. ?
    Ralph Waldo Emerson
    Quote Originally Posted by Fivetide View Post
    The motors will only take what they want so IF the motor need to draw 2A each then it would be 6A total but I very much doubt they they will draw 2A each as you have said they will be operated at very low torque
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. FOR SALE: Nema 34 12Nm stepper motor
    By dsc in forum Items For Sale
    Last Post: 08-05-2014, 01:14 PM
  3. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  4. FOR SALE: Nema 23 4Nm Stepper Motor
    By Shinobiwan in forum Items For Sale
    Last Post: 07-02-2013, 02:15 PM
  5. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
