That unit is for DC motors, I thought you had steppers !
21-11-2016 #2
Ralph Waldo Emerson
21-11-2016 #3
Nope, you need a stepper driver.
It's perfectly possible to drive the step/dir signals into multiple drivers - probably preferable to driving potentially unmatched motors in parallel (and offers a choice of multiple supplies if the load becomes an issue), but its a cost balance for your solution.
FWIW - the motors you spec'd - 2A per phase, I guess 2 phase - that's potentially 4A per motor holding current, so you have to be very aware of driving these in parallel.
Speed and direction control are then determined by the state of the dir signal (CW or CCW) and the frequency of the Step line. You could knock up a speed controller using an Arduino Uno or similar and a few lines of C code, and for relatively little extra cost have a full digital control set-up. Happy to give you more info if you want.
21-11-2016 #4
Ralph Waldo Emerson
21-11-2016 #5
It's a motor where energising multiple windings sequentially results in movement, the stepper driver deals with this, just applying DC or even PWM DC will not run a stepper motor, try it ;-)
Having control of precise steps allows you to use a frequency generator to create a precise RPM
You could just use conventional DC motors with a PWM driver but you will find you have some variation of speed with identical motors driven from a common supply.You think that's too expensive? You're not a Model Engineer are you? :D
21-11-2016 #6
DAMN ! I just want a analogue driver/supply turning all three motors at (approximately) the same speed in a single direction lol
Right then.. 3 of those stepper motor controllers that are all wired to a big pot ? ( I have a box full of big to little Pots )
Plus about 5 shelves of laptop power supplies of every variant I can name !!
I will do this ... it wont bloody beat me ..!! :)Last edited by Fivetide; 21-11-2016 at 11:25 PM.
Ralph Waldo Emerson
21-11-2016 #7
How about 3 of these for playing with http://www.ebay.co.uk/itm/like/30119...0865095&crdt=0
Plus what Rob selected http://www.ebay.co.uk/itm/Stepper-mo...c=1&rmvSB=trueLast edited by Clive S; 21-11-2016 at 11:42 PM.
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
FOR SALE: Nema 34 12Nm stepper motor
By dsc in forum Items For SaleReplies: 0Last Post: 08-05-2014, 01:14 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
FOR SALE: Nema 23 4Nm Stepper Motor
By Shinobiwan in forum Items For SaleReplies: 16Last Post: 07-02-2013, 02:15 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
