    That's a nice machine, I'll ask them when the CNC conversion is likely to be ready. I know that if I can be accurate enough with flipping the material a three axis will suffice for a while, so I don't mind spending the money on a better machine. But I do need CNC from the offset, I've decided that now :-)
    On a scale of 1-5 how terrible will this be if 5 is entirely awful?
    http://www.ebay.co.uk/itm/UK-Stock-4...-/272455253083
    I've had no replies from any suppliers in the UK, so I'm still hunting. My aluminium arrives tomorrow though :)
    Quote Originally Posted by Fingerpuk View Post
    No worse that 4. I reserve 5 for the Merchant Dice toy that I started with. At least with this one axis has supported rails.
    Don't rush to buy something unsuitable.
    Go for the mill, i can explain all day long why. You will learn the business the proper way and will avoid disappointment from the beginning. When if you decide you need a bigger machine you could find easily new home for that one. Plus you will start loving and knowing your machine when you do yourself the upgrade to CNC. Later you can save some cash and add 4rth axis.
    Go for the Chinese router and you will have to change electronics sooner than later, find that machining aluminum is not like they show on videos and that is impossible to produce nice finish and accurate parts.
    And main thing to remember is you need support, especially having in mind you are not and experienced user. So carefully choose what you are saving and from whom are you buying!
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    What Doddy said!
    With a bit effort, it could maybe just about reach a 3, but would still be rubbish for Aluminium.
    I've got a 3040, and build quality wasn't too bad, but some of the components are really rubbish. I only bought it to create a digitiser, so the original electronics got binned, and I had to put a bit effort into getting the mechanics up to a suitable standard, however they really aren't up to any sort of real machining.
    Working on it!
    https://emvioeng.com
  1. Which CNC Router to choose, and what are the costs
    By Painted Letters in forum Machine Discussion
    Last Post: 29-06-2016, 03:54 PM
  2. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  3. Best all round mill/router? Vertical mill or gantry router?
  4. HELP:How to choose
    By sinograver in forum Milling Machines, Builds & Conversions
    Last Post: 17-10-2011, 02:00 AM
  5. How to choose a lead scew
    By GTJim in forum Lead Screws, Nuts & Supports
    Last Post: 15-02-2009, 12:30 PM
