  1. #13
    No I wear tights ! There are three phases to a man's life -Believing in Santa - Not believing in Santa - Being Santa.
    Seriously, I have a problem with drilling a 2mm thick aluminium plate* with 400 holes 3mm dia. The damn thing comes out like a cheese grater, with the top edge of the hole having a sharp raised lip. A bit of coolant cuts down the problem, but I don't know to get rid of this edge lift or burring. The only solutions I can think of, at the moment, are to slow the drill speed down -or- to redo the process but with a 90 degree chamfer bit, drilling to an appropriate depth i.e. 2.1mm, but that is going to add to the time to do these 20 plates and I certainly ain't deburring them by hand.
    Any suggestions ?
    * the ali plate is probably as soft as poodle poo, I don't know what grade it is.
    Cheers,
    Rob
    BTW Lee - if this could go in a better thread or needs to be a new topic - please shift it. Ta - R.
    Being Santa, a 7 and 10 year old - both girls....sorry!? lol
    I've had the same problem, I'm actually after a countersink/chamfering bit recommendation please if anyone has got one to give.
    I end up using a drill bit way bigger than the hole, just give it a quick turn by hand, works quite well on smaller holes, tried a few off ebay all seem to be crap, blunt or for wood.
    Was thinking of adding a "Hand Tool" section to the forums so could split it, Metal Finishing Techniques may be a better place for your question though.
    .Me
  1. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  2. Cheap ebay BOB Build:
    By rbs in forum Gantry/Router Machines & Building
    Last Post: 12-02-2015, 02:47 PM
  3. buying cheap from ebay
    By cjpwart in forum Marketplace Discussion
    Last Post: 08-08-2012, 12:17 AM
  4. Bad Seller
    By fidia in forum General Discussion
    Last Post: 05-08-2010, 05:44 PM
  5. Ebay Seller: Savebase
    By Conan257 in forum Marketplace Discussion
    Last Post: 01-08-2009, 09:42 AM
