I can definitely help here but have to be later tonight, off out now but soft alloy can be thru drilled without a burr on either side.
John S -
20-11-2016 #2
26-11-2016 #3
Being Santa, a 7 and 10 year old - both girls....sorry!? lol
I've had the same problem, I'm actually after a countersink/chamfering bit recommendation please if anyone has got one to give.
I end up using a drill bit way bigger than the hole, just give it a quick turn by hand, works quite well on smaller holes, tried a few off ebay all seem to be crap, blunt or for wood.
Was thinking of adding a "Hand Tool" section to the forums so could split it, Metal Finishing Techniques may be a better place for your question though.Last edited by Lee Roberts; 26-11-2016 at 11:55 AM.
Hi Rob
If i have to drill plate, i don't use a standard grind drill. i grind the size required flat bottom, then relieve it to leave a point in the centre(like a wood drill) this trapanes the hole and breaks through relatively clean, a bit off pecking might help.
regards
Mike
26-11-2016 #5
I haven't got the skill or patience to do regrinding of small drills !
What I am using is a 3.05 carbide drill from this guy http://www.circuit2u.co.uk/epages/63...rill%20Bits%22 He supplies 1st regrind bits at a good price. I am pecking the hole, but am going to play around with the peck and spindle speeds to see what happens.
Cheers,
Rob
26-11-2016 #6
380 holes per piece ! and 20 pieces to do ! sod hand chamfering for a game of soldiers ! I'd end up screaming barmy (nearly there anyway). Here's the dxf, so you can see what I mean STUPLATEb.dxf
Cheers,
Rob
26-11-2016 #7
Rob
If you have a compressor you try a soft abrasive http://www.ebay.co.uk/itm/ECOSTRIP-C...K3a1K2gRapthiA i use this for cleaning Spilka hinges when doing refurb. it might remove the sharp edges.
Mike
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
Cheap ebay BOB Build:
By rbs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 12-02-2015, 02:47 PM -
buying cheap from ebay
By cjpwart in forum Marketplace DiscussionReplies: 4Last Post: 08-08-2012, 12:17 AM -
Bad Seller
By fidia in forum General DiscussionReplies: 8Last Post: 05-08-2010, 05:44 PM -
Ebay Seller: Savebase
By Conan257 in forum Marketplace DiscussionReplies: 2Last Post: 01-08-2009, 09:42 AM
