No I wear tights ! There are three phases to a man's life -Believing in Santa - Not believing in Santa - Being Santa.
Seriously, I have a problem with drilling a 2mm thick aluminium plate* with 400 holes 3mm dia. The damn thing comes out like a cheese grater, with the top edge of the hole having a sharp raised lip. A bit of coolant cuts down the problem, but I don't know to get rid of this edge lift or burring. The only solutions I can think of, at the moment, are to slow the drill speed down -or- to redo the process but with a 90 degree chamfer bit, drilling to an appropriate depth i.e. 2.1mm, but that is going to add to the time to do these 20 plates and I certainly ain't deburring them by hand.
Any suggestions ?
* the ali plate is probably as soft as poodle poo, I don't know what grade it is.
Cheers,
Rob
BTW Lee - if this could go in a better thread or needs to be a new topic - please shift it. Ta - R.Last edited by cropwell; 20-11-2016 at 01:16 AM.
20-11-2016 #2
Rob, if the surface finish isn't critical, then some form of linisher should work. Even a flap wheel in a drill, or flap disc in an angle grinder, but you need to makes sure you clean it if it clogs otherwise you'll just be rubbing aluminium with aluminium.
I hate working with generic sheet aluminium, as it's akin to working with butter.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
20-11-2016 #3
20-11-2016 #4
Thanks for that Lee
£3.71 seems like a bargain to me.
Regards
Mike
20-11-2016 #5
20-11-2016 #6
[QUOTE=cropwell;85406
Any suggestions ?
[/QUOTE]
Pic of it would help but you have probably answered your own question. Soooooo many times i see you guys posting about ally cutting problems and nearly all of the problems are because you do not use grades that are machinable. Use the correct grades that ARE machinable. if you don't you will always have these continuing problems of one sort or another.
Countersink with a very crispy sharp countersink, if the bur is peeling up on one side then you will have a problem of the burr shoving the csk offset and it will be hard to get a neat csk. If the burr is uniform then it should be ok. With very soft materials like this the tendency is to shove the material out of the way as apposed to cutting which itself gives problems even when countersinking because the edge of the hole can not resist the cutting force and the burr wont shear and therefore can also push that burr partially in the hole. It may be an idea to do as mentioned and try a rubbing block to get most of the bur off as possible then csk the hole.
The right material again will save you all this nonsense you are experiencing.
20-11-2016 #7
Ive had one of these type of tools for a while now and they are excellent.
20-11-2016 #8
I can definitely help here but have to be later tonight, off out now but soft alloy can be thru drilled without a burr on either side.
John S -
20-11-2016 #9
26-11-2016 #10
Being Santa, a 7 and 10 year old - both girls....sorry!? lol
I've had the same problem, I'm actually after a countersink/chamfering bit recommendation please if anyone has got one to give.
I end up using a drill bit way bigger than the hole, just give it a quick turn by hand, works quite well on smaller holes, tried a few off ebay all seem to be crap, blunt or for wood.
Was thinking of adding a "Hand Tool" section to the forums so could split it, Metal Finishing Techniques may be a better place for your question though.Last edited by Lee Roberts; 26-11-2016 at 11:55 AM.
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
Cheap ebay BOB Build:
By rbs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 12-02-2015, 02:47 PM -
buying cheap from ebay
By cjpwart in forum Marketplace DiscussionReplies: 4Last Post: 08-08-2012, 12:17 AM -
Bad Seller
By fidia in forum General DiscussionReplies: 8Last Post: 05-08-2010, 05:44 PM -
Ebay Seller: Savebase
By Conan257 in forum Marketplace DiscussionReplies: 2Last Post: 01-08-2009, 09:42 AM
