    Shouldn't need to enable the drive moray nothing special needs to be done. If everything is correct it should enable on power up and lock motors. When working and if not tuned the motors will make an hissing sound.
    When using the Current loop thru software or Flicking dipSw #4 the motor will buzz for sec then stop hissing.
    I'd be very surprised if you have Dead drive because I've fitted loads of these and AM drives never had faulty one yet so check your wiring.
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    That's what I thought, but it's not doing anything.
    I doubt there's a problem with the drive. It's more likely I'm missing something obvious.
    Power is OK, it's not faulting so there must be a motor connected, although I'm relying on the markings on the original wiring that I've got the correct motor. Even still, I would of thought the Current Loop screen would of shown something.
    Only other wires I've got connected are the step/dir wires, but they're not powered up yet, as the line driver board that will drive them hasn't got a power feed yet.
    I'll reset the drive and try again in the morning, as I'll need to squeeze behind the machine to listen to the motor.
    So after a reset, a drive power cycle, and checking the settings again, I realised the phase fault detection is not activated as standard. Why you wouldn't enable all the fault detection options as default I'd love to know..
    After activating it, the drive went straight into fault. Following a bit probing with the multimeter, and some tugging on wiring, I discovered one of the contact pins for the motor wiring had pushed out the main multiplug on the mill for connecting the control box. It pushed and locked back in, so I'm not sure how it had come out, but I now have movement, and the auto current loop configuration worked.
    I'm sure I'll be back with more questions about the anti-resonance tuning, but that can wait until I have all axes working.
  1. Servo Tuning - any experts here ?
    By Davek0974 in forum Machine Discussion
    Last Post: 08-09-2016, 08:10 PM
  2. Leadshine EM / AM Anti Resonance & Current Loop Tuning
    By CNCStudent in forum Motor Drivers & Controllers
    Last Post: 05-03-2015, 04:01 PM
  3. Tuning Leadshine EM806 with SY60STH86-3008B
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 17-02-2015, 08:18 PM
  4. Help please with motor tuning mach 3.
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 13-06-2012, 10:22 PM
