23-11-2016 #11
I think you are asking a lot of a machine with unsupported rails on all axes. Maybe put some better rails on your Christmas list!
Yet another way to check the XY axes are perpendicular is do put some MDF on the bed and drill holes in the corners of a rectangle, then push drill bits in the holes and measure the diagonals with a digital caliper. Size the rectangle to match your biggest caliper.
You should also try measurements on different parts of the bed - e.g opposite corners. This will tell you more about the source of the error.
To make sure it's not something electrical (I doubt it too), you could try zeroing the machine at a known point on the dial indicator, then run some random g-code:
http://www.mycncuk.com/threads/5843-...g-motor-tuning
If anything will cause it to loose position, that should do it.
Edit:
A note on ballscrew accuracy - C7 is up to 0.05mm over 300mm. This doesn't mean the error is distributed over the 300mm, e.g. a screw with a 0.04mm error over 40mm and 0.01mm error over the remaining 260mm would be classed and sold as C7. This sort of error (though hopefully not as extreme as my example) is more likely than an error over a broader distance, as if that were the case the manufacturer could compensate for it similarly to how you might do so in software. That's why I'd be wary of entering anything other than the calculated value for step/mm, as it will compensate only for the portion you measure, on average. You need to be very confident of the measurement accuracy to do this.Last edited by Jonathan; 23-11-2016 at 01:50 PM.
mach 3 scaling issue
By terry1956 in forum Artsoft Mach (3 & 4)Replies: 22Last Post: 01-02-2019, 11:32 AM -
Up-scaling CNC Sidewinder to cut 8x4?
By toby in forum Machine DiscussionReplies: 4Last Post: 11-05-2015, 09:15 AM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
What the hell do I need ?? (humourous replies expected :-) )
By alboy in forum Marketplace DiscussionReplies: 9Last Post: 08-09-2013, 12:42 PM -
Two ball screws for my x axis and two motors, do i need two drivers?
By luke11cnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 12-08-2011, 12:55 AM
