I don't exactly agree with this but at same time I do.?
Completely agree that not good idea to use over short distance but if done over the full length or large portion of screw then can set the machine up very accurately, much more than working to fixed calculated values which don't account for screw or other factors like belts/pulleys.
However to do this requires very accurate measuring device done over long distance.
I set machines up using Glass linear scales to verify movement and find that if using timing belts/pulleys this is only way to very accurately set machine up as the calculated values often don't get it spot on. Even when direct mounted there can be some error but to much lesser degree.
So case of Yes and No to me also how accurate or Anal you want to get about it.??
However in this case I'm 99% sure the issue is compulation of mechanical and design weakness.Last edited by JAZZCNC; 23-11-2016 at 03:01 PM.
mach 3 scaling issue
By terry1956 in forum Artsoft Mach (3 & 4)Replies: 22Last Post: 01-02-2019, 11:32 AM -
Up-scaling CNC Sidewinder to cut 8x4?
By toby in forum Machine DiscussionReplies: 4Last Post: 11-05-2015, 09:15 AM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
What the hell do I need ?? (humourous replies expected :-) )
By alboy in forum Marketplace DiscussionReplies: 9Last Post: 08-09-2013, 12:42 PM -
Two ball screws for my x axis and two motors, do i need two drivers?
By luke11cnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 12-08-2011, 12:55 AM
