Thread: Measuring internal diameters
Cheers Mike, Lee, Komatias
The guy I've been watching a lot recently is Stefan Gotteswinter and he likes to use the internal mic. But yes many others use the telescopic gauges and then mic them.
In the work discussion calipers were mentioned as a very cheap way to measure bores (I already have the external mic), but takes some feel/practice. I forgot to mention that above so thanks Mike. Great to hear you worked in the inspection area - that's what I like about this forum, such a wealth of experience to tap into. So I'll most likely get an internal caliper anyway and have a play - not that expensive.
Dial bore gauges look interesting, one to think about.
I'll sleep on it and bit more . . . .
23-11-2016 #2
Dial bore mic's are expensive and you still have to check them with gauge so in all honesty i don't think its a very good investment unless you pick up something cheap on ebay.
with spring loaded internal calipers you can get a good feel ( polish the tips to form a nice ball end) and as long as you duplicate the same touch when brushing the anvils of your external mic you will get a good reading.
Good luck
Mike
The Following User Says Thank You to mekanik For This Useful Post:
26-11-2016 #3
When I found these I thought of this thread
You can pick up sets of Diatest Gauges for reasonable money on ebay from time to time, they are very quick and easy to set up as you slip the assembled gauge into the standard and set the dial gauge in the sleeve to read the exact size, repeatability is fantastic and you can check the bore at various depths if necessary, I use them for assessing chamber wear in barrels.
To swap to metric you just use a metric dial guage and a calculator to convert the standard size to metric for zeroing,
- NickLast edited by magicniner; 26-11-2016 at 01:09 PM.
The Following User Says Thank You to magicniner For This Useful Post:
26-11-2016 #4
Cheers Nick,
Another one into the mix . . .
advise on drive shaft diameters
By bmbaz in forum Machine DiscussionReplies: 2Last Post: 15-05-2014, 10:46 AM -
5/8th internal rotary broach
By davy the car in forum Tool & Tooling TechnologyReplies: 0Last Post: 17-02-2014, 11:39 AM -
RFQ: Internal Spline Broaching
By Mad Professor in forum Projects, Jobs & RequestsReplies: 6Last Post: 23-07-2012, 06:14 PM -
internal rad
By benkat in forum Machine DiscussionReplies: 0Last Post: 11-01-2012, 11:17 AM -
Ho do you measure end mill diameters?
By HankMcSpank in forum General DiscussionReplies: 10Last Post: 21-11-2011, 12:04 AM
