Thread: PSU question
I suspect that the Gecko recommendations are based on linear power supplies. The trouble with switch-mode supplies is that they can hard-limit at max current which gives stepper drivers a problem when they demand short but high-current pulses. Linear supplies with their big smoothing capacitors will handle this with no problem - it doesn't matter in this situation if the output voltage drops a few volts when you demand higher than rated current for a few milliseconds. If you are looking at cascading a switch-mode inverter off the back of a switch-mode power supply, it might not handle this kind of load very well. Linear supplies needed to be rated for average demand, switch-mode for peak demand, as a general guide.
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
PSU question
By Dwayne Dibbley in forum General ElectronicsReplies: 16Last Post: 13-02-2013, 10:15 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
A question
By bodgeitandscarper in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-12-2009, 08:30 AM
