I have ordered or already have everything for the DC and Stepper builds.
They both have merits :
The stepper build linked to an arduino program will be good for taking the roughed out semi-sphere to an unpolished perfect sphere. I can set the program to speedup gradually and shift the rotational direction. More torque is required because it tends to grab when rough.
But it takes more parts and is a more expensive build. You have to have 3 controllers , flexible adapters and chucks.
The cordless drill version is good for the high speed polishing where torque is not a huge issue, it can also be controlled with an arduino and has a built in gearbox / chuck. Its also a cheaper build, 1 power supply and a single controller. Bit more cooling needed if there is no built in fans.
If .. and I say if ! I get them both working I'll do a vid and some pics.
Ralph Waldo Emerson
29-11-2016 #2
05-12-2016 #3
Well it worked , thanks guys, pretty simple in the end with your help..anyway a vid .. sounds like a jet engine taking off lol :)
Ralph Waldo Emerson
06-12-2016 #4
Cool, good to see you have something running, now we just need to see them working on your spheroids ;-)
I know it looks wrong but the other options were worse! :DYou think that's too expensive? You're not a Model Engineer are you? :D
About to take the plunge - quick power question 3020 CNC
By Sherpa in forum Chinese MachinesReplies: 5Last Post: 23-09-2016, 10:41 PM -
Just starting out - quick question
By glynster in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-02-2015, 06:20 PM -
quick question about lead screw
By japcarmaniac in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 09-02-2013, 11:25 PM -
Quick cable question
By PWD in forum General ElectronicsReplies: 18Last Post: 11-12-2012, 09:25 PM -
Quick question
By m.marino in forum General DiscussionReplies: 2Last Post: 18-02-2011, 04:30 PM
