29-11-2016 #1
I'm looking to source a couple of lengths of supported rail for an experiment I have in mind. Just trying to keep the spend within limits, because the plan might not work, hence casting around for a used pair. I know quite a few builders on the forum have in the past upgraded their unsupported rail to profile rail, and so wondered if anyone had some redundant rails kicking around!
I'm not fussy as to what size rail it is - ideally 16mm or more, but even 12mm would do it! Length has to be at least 750mm, but I'm happy to trim accordingly. And if it comes with any bearing blocks, then all the better - but not essential. I only really need one per rail for what I have in mind, so purchasing these new wouldn't break the bank.
Thanks in advance!
Graeme
WANTED: Supported rail. The bigger the better
By r0bsk1 in forum Items WantedReplies: 0Last Post: 08-07-2013, 07:50 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM -
Some thoughts on using supported rail
By Ross77 in forum Rails, Guideways & BearingsReplies: 0Last Post: 29-01-2010, 07:13 PM -
Supported rail or other?
By lateAtNight in forum Rails, Guideways & BearingsReplies: 16Last Post: 14-11-2008, 02:28 PM
