    I took the OPs rule one as 'don't spend any money on bits until the design is ready, research done, etc (rather than do it cheaply). Otherwise money wasted on poor choices . . . And no one including Yorkshiremen like to waste it'
    Either way no matter, good luck with it. Perfectly possible to build a machine to do what you want. Trick is not to let machine building become the hobby.
    I took the OPs rule one as 'don't spend any money on bits until the design is ready, research done, etc ' rather than do it cheaply. Otherwise money wasted on poor choices . . . And no one including Yorkshiremen like to waste it
    Yep, that is how It was intended, but nice to have a confirmation on the budget, for "She who must be obeyed"
    I'll try not to let it become the hobby, but its all work and shed related - I fully intend to make it pay for itself.
    I see you like to cut dovetails. Have a look through this thread posted by Gerry:
    http://www.mycncuk.com/threads/7688-...ovetail-joints
    Thanks for that, I am way off the software side of things yet, but glad someone has already done the work for me.
    On length of work, I did this credenza and nest for someone and put dovetails on the end of the top (8 feet long) by clamping the Leigh dovetail jig onto the workpiece and using the router verticaly.
    If you see what I mean?
    But dont think a CNC could do that, well I havent alowed for it in my design. I suppose a rotating spindle thru 90 degrees on anther axis would do it.Click image for larger version.
    Quote Originally Posted by OMLCNC View Post
    You don't have to -
    http://www.tailmaker.net/
    - Nick
    You don't have to -
    - Nick
    But those aren't "real" dovetails.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    In the strictest sense possibly not, but you don't need special software for conventional dovetails with a dovetail cutter, just decent CAM ;-)
    - Nick
    You don't have to -
    - Nick
    Thanks Nick, Looks great I have earmarked the web site and will look at it when I'm getting near completion of the build.
    Long way to go before then.
    Robert.
  1. NEW MEMBER: On a steep learning curve
    By Laurie in forum New Member Introductions
    Last Post: 01-09-2016, 06:57 AM
  2. Training / Self learning
    By manofgresley in forum Programmers Corner
    Last Post: 27-02-2014, 01:25 PM
  3. A learning process
    By cropwell in forum Milling Machines, Builds & Conversions
    Last Post: 21-02-2013, 07:38 PM
  4. NEW MEMBER: Learning with MYCNCUK
    By Goran in forum New Member Introductions
    Last Post: 10-12-2010, 06:08 PM
  5. NEW MEMBER: Old timer, still learning, Virginia, USA
    By GerryR in forum New Member Introductions
    Last Post: 13-10-2010, 10:41 PM
