    The Leigh jig has templates for some really strange-looking "dovetail" interlocking joints. Not sure how many of them are possible with CNC...
    This is true, but they are expensive £564.96, I think (But they were made on a "Precision CNC Machine" in aluminium alloy according to the catalogue), so what could I do with my machine when its built? (Naughty)
    No I won't do that I will be designing and programming my own or using someone else programme, its this infinite possibility idea of CNC that I like.
    Erm, that is not correct,
    And I quote - "All G-Code is to be executed with a 30-degree engraving or V-bit." ;-)
    My mistake, I was thinking of Fingermaker.
    But the principle is the same. Lots of passes with a small bit, and no other option.
    Bottom line, as with any CAM software, use whatever you like best.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    You can use as big a cutter as you like as it's the angle that matters, watching the video it's not particularly slow or limited to tiny cuts either.
    The main feature is all the things it cuts only require the material to be mounted at 15 degrees from horizontal meaning ordinary routers can cut joints on the end of long boards.
  1. NEW MEMBER: On a steep learning curve
    By Laurie in forum New Member Introductions
    Last Post: 01-09-2016, 06:57 AM
  2. Training / Self learning
    By manofgresley in forum Programmers Corner
    Last Post: 27-02-2014, 01:25 PM
  3. A learning process
    By cropwell in forum Milling Machines, Builds & Conversions
    Last Post: 21-02-2013, 07:38 PM
  4. NEW MEMBER: Learning with MYCNCUK
    By Goran in forum New Member Introductions
    Last Post: 10-12-2010, 06:08 PM
  5. NEW MEMBER: Old timer, still learning, Virginia, USA
    By GerryR in forum New Member Introductions
    Last Post: 13-10-2010, 10:41 PM
