Thread: Old Man Learning CNC (OMLCNC)
04-12-2016 #14
If you have basic CAM and a clue you can generate the required paths for dovetail cutters to cut dovetails, at it's simplest you can tell your CAM that the cutter is the largest OD of the dovetail cutter, use the geometry at the base of the cutouts and fudge it a little to ensure that the Z moves take place off the part.
Taper cuts with taper cutters don't always need 3D CAM that can use the cutter shapes, just someone making intelligent use of the tools available to him,
NEW MEMBER: On a steep learning curve
By Laurie in forum New Member IntroductionsReplies: 14Last Post: 01-09-2016, 06:57 AM -
Training / Self learning
By manofgresley in forum Programmers CornerReplies: 3Last Post: 27-02-2014, 01:25 PM -
A learning process
By cropwell in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 21-02-2013, 07:38 PM -
NEW MEMBER: Learning with MYCNCUK
By Goran in forum New Member IntroductionsReplies: 1Last Post: 10-12-2010, 06:08 PM -
NEW MEMBER: Old timer, still learning, Virginia, USA
By GerryR in forum New Member IntroductionsReplies: 1Last Post: 13-10-2010, 10:41 PM
