Ok don't get yourself in a flap its a bit like having to lean a foreign language you pick a few words up but they don't make sense.
Tramming is just adjusting the spindle so that is perpendicular to the bed ie. if it was lopsided and you was making a cut the tool would be leaning over to one side and that would make it cut on one edge more than the other.
You don't need to buy a fancy tool to do that you can do the same job with a DTI (dial indicator) which you will need anyway.
Re the Transwave it is of no practicable use for the spindle you will need a VFD and with that you can vary the spindle speed.
You will need a decent size box about 600 x 600 x 200 ish to fit every thing in. Personally I don't like putting the VFD in the control box .
Hope all this helps but it is better to ask questions rather than buy a load of junk like kits of parts.
Yep that helps Clive, I have DTI, can you use an old PC case for box? I think I have seen that done?
