Let me just point something out that is easy trap to fall into and one that Joe has made which I hadn't spotted until now.? (Sorry Joe just seen your Video using drill, well done on first movement.)
You need to leave access to the bearing bolts so the gantry can easily be squared to the linear rails. How joe has it now means to square up he'll be putting twisting action on the bearings because can't get to the bearings because of profile.
Better way to do this is to split the job and have separate bearing plate which holds the Ball screw mounts etc and then have another plate which is part of Main gantry which then just sits on and bolts to the bearing plates. This can then be drilled & reamed and pinned when everything is square.
Much easier to setup and take apart if needed. The gantry becomes separate entity which can easily be removed and put back without too much hassle.
I'll repeat my self because can't be stressed enough ADJUSTMENT, ADJUSTMENT, ADJUSTMENT then some more ADJUSTMENT is key at DIY level to keeping the stress levels low. . .
Name:	CNC MACHINE DESIGN 5 6 Dec 16.jpg
So is this what you propose, (Two plates marked in green) to be drilled with oversize holes and the bearing plate to be tapped to accept bolts, when finished adjusting, drill, ream and pin together?
Other green items added are the table adjustment brackets.
