Thread: Project Beaver
  1. #31
    Quote Originally Posted by MikeyC38 View Post
    I like the idea of the dust cover on the Z axis. Dust gets everywhere especially cutting wood. I've made a dusthood for mine which connects to my Cyclone filter - see here post #56 and it helps. What type of endmill, feeds and rpm did you use on the Walnut?
    Mike
    Dust Cover is a copy of Dean's, there's a picture of it somewhere on the forum. I did add a flat piece of sheet on the bottom of the Z axis to try and stop chips and dust going up inside as well.
    The Walnut I used 3 router bits, 18mm end mill for surfacing and cutting the hand hold pockets and profiling the edge of the board (12000rpm 60mm/sec), a 19mm ball nose bit for the well, spot and gutters (12000rpm 40mmm/min), a 12mm v 90 degree bit for the spikes. (16000rpm 40mm/sec).
    I'm still experimenting and getting lots of things wrong (you can see were I forgot to check the tool hight and it dived into the board near the well - I did a repair - and lots of swearing)
    You need lots of scrap material - I have made about 8 of these boards before I got one acceptable. They take about 45 minutes start to finish with tool changing and 5 minutes of sanding to clean up.
    I have made a couple of dust shoes and seen your cyclone set up (I have read your entire build).
    I have a double bag dust extraction system 125mm dia pipe. The latest dust shoe is made out of a piece of drain pipe and works well even if it looks a dodge. I will take a picture for you to laugh at some time. I tend only to use it when I'm happy with the program, so I can see when the tool has broken or dived into the job!
  2. The Following User Says Thank You to OMLCNC For This Useful Post:
  1. Beaver NC35 Mill
    By sshep71 in forum Milling Machines, Builds & Conversions
    Last Post: 14-09-2024, 11:01 PM
  2. FOR SALE: CNC project
    By amxen in forum Items For Sale
    Last Post: 20-12-2015, 09:19 PM
  3. Bound Quill on a Beaver BVRP
    By 87bob in forum Milling Machines, Builds & Conversions
    Last Post: 12-08-2014, 02:51 AM
  4. NEW MEMBER: Logging in to follow Andre's Beaver mill conversion
    By Damocles in forum New Member Introductions
    Last Post: 05-09-2010, 01:32 PM
  5. Beaver on eBay
    Last Post: 22-01-2010, 09:33 PM
