    Just found these on eBay, £10 inc P&P !
    Description
    Switching power supply, closed, 24V / 8,3 A / 200 W
    Switching Power Supplies with built-in RFI filters. Low ripple, closed design with screw terminals. Overload protection by switching off, auto recovery. Short-circuit proof. 100 % burn-in test under full load.
    Power: 200 W
    Input: 85 - 264 VAC, 120 - 370 VDC
    Output: 24V / 8,3 A
    Manufacturer: MEAN WELL
    Article number of the manufacturer: SP - 200 -12
    Packaging weight: 0.849 kg
    RoHS compliant
    General type switching power supply
    Execution closed
    Electrical values
    Voltage 24 V DC
    Current 0 - 8,3 A
    Input Voltage 85 - 264 VAC
    Input voltage 120 - 370 VDC
    Inrush 60A
    Ripple 100 mV
    Features
    Short circuit protection yes
    Overload protection yes
    Connections / Interfaces
    Connection Screw
    Link: http://m.ebay.co.uk/itm/162036991360
    Bargain no?
    .Me
    Oh bu**er. I just went and bought one for a higher price from aliexpress a few days back and I now have to wait a month for it to arrive.
    Quote Originally Posted by nirmal View Post
    If you are going to use this with your nema 23 motors and am882 drives then you will not get the best from them. 60-70V would be better.
    I've ordered a 60V 10A Mean Well for powering the motors. I also bought a separate 24V 3.2A power supply for powering the motion control unit (DDCSV1.1). It requires 18-32V >0.5A. I am thinking of using it to power a little 24V brush-less dc submersible pump for spindle cooling also.
    Damn it sorry about that!
    This 24v one is the best price I could find vs form factor, it's only a 2amp rating power supply so it depends if you want to run other stuff from it, the problem/issue (for me at least) was that as you start going up in amps, the size of the unit gets bigger.
    DC 12V/24V/5V Universal Regulated Switching Power Supply for LED Strip CCTV Hot
    Link: http://m.ebay.co.uk/itm/222029680440
    There is plenty of other sellers on there, the best prices seem to be coming from the sellers advertising these switch mode psu's as l.e.d driver units, there's quite a range to choose from once you start looking.
    Just a note to anyone reading: Ideally you want a linear power supply to power your motors/drivers really, switch mode units do work though.
    .Me
    This one is the best 5v one I could find, again unit size being the factor:
    AC to DC 5V 5A 25W Volt Transformer Switch Power Supply for Led Strip Light PO6Z
    http://m.ebay.co.uk/itm/172053699383
    .Me
    Little update, I needed a couple of 12's recently for a project and found the listing below has a pretty good selection for 12v and 24v switching power supplies: 25W/30W/50W/60W/100W/120W/150W/180W/250W/300W/360W/400W
    12v 80w 6a £10
    http://www.ebay.co.uk/itm/282219610030
    12v 25w 2a £6.50
    Did you get them OK? this eBaytrader has some shitty feedback in the last month. Still a Meanwell PSU is a fairly good one !
    R
    R
    Still when i hear Mean Well i want to respond " but Went Bad"
  1. Power Supplies
    By dcrowder in forum Machine Discussion
    Last Post: 27-01-2016, 08:32 PM
  2. Power Supplies
    By GTJim in forum General Electronics
    Last Post: 26-04-2013, 04:06 PM
  3. Replies: 0
  4. FOR SALE: Power supplies
    Last Post: 21-05-2011, 07:37 PM
  5. FOR SALE: 3 x 48V 12.5A Power supplies for sale
    Last Post: 25-03-2011, 07:18 PM
