    I bought some :
    BLACK MALLEABLE IRON REDUCING PIPE FITTINGS BSP - SOCKET, BUSH, TEE, HEX NIPPLE
    ( 111520014759 )
    Fitting Type: REDUCING BUSH
    Size: 1/2" x 3/8"
    When they arrived I was surprised my 3/8" male threaded pipe didn't fit ?
    So I emailed the vendor and said although you have 1/2" to 3/8" stamped on the Bush its actually measures 14.1 which I think is 9/16 0.5625 or 14.2875mm well near enough.
    Anyway I emailed the guy and this was his reply
    hi David, there is no such size as 9/16" , the fitting is correct just check . (there is sizes cast on fitting one side of hex part)
    1/2" X 1/4" bushes have a inside 11mm if any better for you.
    Here's me thinking 1/4" was 6.35mm ?
    I'm confused
    Pic attached
    As Robin has stated an interest in "having fun" I withdraw my earlier request...your all now free to continue with lessons and raucous finger pointing !! :P
    Hold on indeed, you ask if you are being dumb and then say, "No need to answer" ???
    Where's the fun in that? :)
    Ralph Waldo Emerson
  1. Dumb Reverse
    By Leadhead in forum General Discussion
    Last Post: 03-10-2016, 12:41 PM
