Page 2 of 2 FirstFirst 12
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Quote Originally Posted by Fivetide View Post
    Ok Neale thanks for the reply, I'm trying to get to a point where I can screw in a 3/8" bolt to the bush after I've ground the head off and fit it into a chuck capable of taking up to 13mm. if that makes sense ?
    Sorry but I have to ask again - what 3/8" thread? If it's an old bolt, then it might be (imperial) BSF or BSW, newer might be (unified) UNF or UNC. Might, just, if it's a bit sloppy on its OD, be M10, depending on how accurately you have measured it. You might end up having to buy a matching tap and making it yourself, unfortunately, unless you have a kind forum member nearby with a lathe and good set of taps!
    Edit - I see that you've more or less reached that conclusion!
    Screw Size: 3/8" UNF x 1.1/2" long Thats what I found will fit in the chuck , thats why I thought it would fit in the bush.. that sounds naughty lol :)
    Ralph Waldo Emerson
    I may have come up with a cunning plan :)
    I found these Push Fit Stem Adaptors they may be strong enough for what I need , but if not I can cut off the stem and tap out the nut.. may work but hey I love a challenge :)
    Ralph Waldo Emerson
    You maaaaay be asking a lot from Acetal, but you could always put a steel rod down the centre and bond it in.
    Cheers,
    Rob
  5. #15
    Cheers,
    Rob
    Shit ! I thought they where steel FFS ..cancel that order then :(
    Ralph Waldo Emerson
  6. #16
    Sorry mate - they may be metal, but most of the ones I have seen are acetal. I would give Bob or Chris at Context a ring and check it out. You could always use a brass hosetail ??? - Rob
  7. #17
    It does say Plastic, I have canceled them . They are a bit steep if plastic as you can get a the same size stainless steel for £3 and they come in at £2.50 ?
    Ralph Waldo Emerson
  1. Dumb Reverse
    By Leadhead in forum General Discussion
    Last Post: 03-10-2016, 12:41 PM
