    Boyan,
    there is only one extruder worth using. It is also worth going direct drive on such a large build.
    The Bondtech extruders are E3D compatible so at least that is a good start.
    https://emvioeng.com/shop/3d-printin...ndtech-qr-3-0/
    You will need to heat the bed to allow adhesion and reduce warping. Think about how you are going to acheive this on a 6mm surface.
    The rest seems legit
    looking forward to seeing what you get up to.
    Quote Originally Posted by komatias View Post
    Boyan,
    Thanks for pointing me there! I will probably contact you as i need some quality components.
    I will greatly appreciate your input if you are kind enough to share info.
    But about the extruder:
    -First of all its a proprietary extruder, not open source, so no place in my build. Why? Obviously to make my printer i will use open source electronics, hotend, etc. So roughly said- i am basing on other peoples work half of the printer. Isn't it a better thing to buy their products to sponsor them continue the investigation? I think so.
    -Even if its the best extruder on the market and probably very nice to resale as a high end extruder with a good mark up value, i dont think thats the correct extruder for the build. Though for special order build or for a desired upgrade i could eventually use it.
    -Third but not least- See, i will ask you a question. if i am to make a printer for resale, could you resale more easily that printer it it has 4 x Bondtech or a printer that has 4xextruders that do the same job 95% and are altogether combined cheaper than one of the Bondtech?
    400x200 bed. I was tempted to go 400x400 or even 500x500, but i decided that quality is better than quantity. First of all 2x 200x200 heating pads or elements will do the job cheaply. Then silicone heating pad may be . What i am contemplating is to use even 8-10mm plate, pocketed seriously from bottom and using heating wire directly or silicone pad there.
    One thing is a must: the bed must not "breathe"
    and when pulling sth from bed machine must not need recalibration In fact- i will not accept to say that i did sth good if the machine will need any kind of later software adjustment and squaring of bed. Thats why i did not like the "raising Z design and shied away from it though people praise it. No way, its not my direction of design and thought. Even if i have to move the bed with 2 motors or a real servo motor to achieve the needed acceleration.
    I have 3d printer from 3 days at home and have not seen or contemplated 3d printer design earlier. And the first thing that bugged me was pulling away the piece from the glass. I thought i will brake the bloody toy.
    I could and possibly will use the way the Prusa does it with the touch probe, but better design everything so that is not actually needed.
    PS:
    bed heat insulation from below is a must also! and i will not shy from thermocontroller if need be. its just ~20 euros altogether with SSR relay.
    Questions:
    -If the printer is fully enclosed, do i need to cool the things down inside the enclosure somehow? I am not talking about the electronics. But do the electronics support that function? or just leave a hole so air circulates?
    -Another question as i have 30x30 profile here and have never seen in real life 20x20 profile. Will it be ok for the gantry only one piece of 20x20 at high speeds? will it not vibrate? Thats my only doubt from structural point of view.
    -haven't somebody come with super light direct drive helper combined with Bowden extruder solution? In real life i see the 4 spols in a dry box 1.5 meter away at least from printer. I dont see them hanging around and sucking humidity from air, and i live 200 meters from sea and this is a serious problem.
    In fact from a couple of days i dont stop the air conditioner at all at home, because i still have not made myself a dry box for the filament
    if not- too bad but anyway i dont care much about flexible filament, so Bowden drive will be
    There is a very neat extruder design on this thread. https://forum.e3d-online.com/index.p...led-mod.53/The water cooled hot end design on the same thread might also be a good idea if you find that a heated chamber is necessary to keep super sized prints from warping.
    You can order custom made silicone pad heaters from china in whatever size you require. I presume you will go for 240V AC and a solid state relay for the bed heater. I am not sure if any of the commonly used controllers will allow the sort of currents you will need to pass through them without overheating if you go for DC and on-board PWM heated bed control.
    On the subject of control boards, the Duet WiFi with the TMC2660 stepper drivers would allow you greater a choice of stepper motors with it's high current rating and as an added bonus would be very quiet in operation. I have no connection with the Duet manufacturers. I am just the owner of a previous version of the board - purchased for a still unfinished project.
    Sorry I messed up the link. Here it is https://forum.e3d-online.com/index.p...cooled-mod.53/
    Quote Originally Posted by nirmal View Post
    It's easy to do your control on the AC side of a transformer/rectifier circuit using a PID controller and solid state relay ;-)
    WOW! I got my first 3D printer for my birthday back in 2012, wore it out by 2015 and I bought another.
    I have absolutely no advice to offer because I believe 3D filament extrusion printing to be a black art and beyond earthly comprehension. Every time I think I understand it a new torment pops up and hurls me back to square one.
    I would say, "Good luck" but I do not want to jinx you.
    Break a leg
    Robin
    Similar to Robin - had a couple of 3D printers for a few years now. Just a point to Boyan - remember the nature of the material that you're dealing with here - it's a laudable design goal to have a tank-build, but there *WILL* be deformation of the extruded material that WILL cause head crashes - I've been watching mine recently and some of the flex in the design accommodates the fast traverses together with a clearance height that is intruded upon by the cast material. A bit of flexibility could offer protection to the extruder.
    EDIT: (tongue-in-cheek) maybe in keeping with the nature of this site, Boyan should design a co-axially mounted fly-cutter to machine the build surface!
    and a 300degC air blower to soften the top layer before deposition should you dare to print any substantial area :distrust:
    I'd also like a micrometer adjust on the Z axis so I can tweak it without reprinting. A mere 0.1mm too low on the first layer means no squidge and I lose adhesion :fat:
    I prime the bed using an ABS wash over Kaptan over Pyrex over aluminium, with yellow dusters on top for a quick warm up. What a palaver. No wonder ebay is full of patent sticky beds :stung:
    I used to use cheap ebay filament but now only the best will do, and small reels because you only wind up throwing the excess the moment it has sucked enough moisture out of the air. Pop fizz :culpability:
  1. Here comes my DIY 3D printer
    By A_Camera in forum 3D Printing Machines
    Last Post: 25-06-2018, 10:50 AM
  2. 3D printer and CNC routers
    By thinfourth in forum 3D Printing Machines
    Last Post: 05-10-2017, 05:19 PM
  3. Building my own 3D printer
    By Washout in forum 3D Printing Machines
    Last Post: 22-08-2014, 03:15 PM
  4. New toy, Afinia 3D printer
    By Robin Hewitt in forum 3D Printing Machines
    Last Post: 05-07-2014, 11:18 AM
  5. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
