    I'd also like a micrometer adjust on the Z axis so I can tweak it without reprinting. A mere 0.1mm too low on the first layer means no squidge and I lose adhesion
    Agreed - one of the first things I printed with mine (early Prusa now around 5 years old) was a fine Z height adjuster. Invaluable. I would also like auto bed levelling - I take my printer to exhibitions from time to time (good machine for this as you can see all the working parts very easily) and it doesn't travel too well. Always needs 10-15 mins of fiddling around to retweak the bed (heat-proof glass on PC board heater). I managed to find a ground glass trivet in a local discount hardware place which gives very good adhesion with no more effort than the occasional wipe with acetone.
    I keep wondering about frosting it with a waft of hydrofluoric acid, trouble is HF really does everything H&S warns you about for everything else. It really does kill you and all the hospital can do is make you a cup of tea and contact your next of kin. Back in my youth the chemistry books told you how to frost glass by dissolving old teeth
    I remember the school chemistry book with a picture of a hand that had been dipped in HF. I treated the bottle of HF with care after that; doubt if it would be allowed within miles of a school these days!
    A friend of mind is a sculptor/artist working with glass and she tells me that sandblasting is the way to go. Certainly with PLA, it works well, and as Boyan says with PVA glue, you need to let the glass cool for some time before the print comes free. I typically print with a bed temp of 60C, but of course that depends on how accurate the bed temp measurement is. At least it's a lot less critical than hot-end temp.
  1. Here comes my DIY 3D printer
    By A_Camera in forum 3D Printing Machines
    Last Post: 25-06-2018, 10:50 AM
  2. 3D printer and CNC routers
    By thinfourth in forum 3D Printing Machines
    Last Post: 05-10-2017, 05:19 PM
  3. Building my own 3D printer
    By Washout in forum 3D Printing Machines
    Last Post: 22-08-2014, 03:15 PM
  4. New toy, Afinia 3D printer
    By Robin Hewitt in forum 3D Printing Machines
    Last Post: 05-07-2014, 11:18 AM
  5. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
