Thread: Build log at last
I know you shouldn't buy anything until I have the design finished but i have been offered 3 X AM882 drives for £110 would this be a good buy and work well for this machine, With my knowledge off electrics not great i want to keep the electrics as simple as possible .After reading some more build logs am i right in thinking that 1610 ballscrews all round would be ok for this machine with Nema 23 Stepper Motor 3Nm all round or Nema 23 Stepper Motor 4Nm?
Cheers Greg
22-12-2016 #2..Clive
06-01-2017 #3
Thanks for all the advice
I have made a start on the design off the z axis which i am not sure if i have worked out the travel right so any advice would be great,I change the profile for the Y axis L shape to 90x45 I think it was in a post by Jazcnc that I was reading that it is handy for fitting the Hiwin rails to. Here are some pics with the measurements
Cheers Greg
07-01-2017 #4
Why have you gone for the square shape on the gantry sides as your previous post you shows it different. It might be better to show the z axis in more detail as you will need a cutout on the back plate and the front plate to accommodate the ball nut.
07-01-2017 #5
07-01-2017 #6
If you have not bought your screws yet the Y screw could be made shorter and the pulley and the motor could be inside the gantry as you won't be using the full length of the screw.
Are to still at the drawing stage or have you started with the build?..Clive
07-01-2017 #7
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
