    Lives in Plymouth, United Kingdom. Last Activity: 13 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm going to be engraving some control/switch panels in Traffolyte or one of its equivalent engraving laminates. I haven't done this before, and I'm not sure what angle cutter to use. I had anticipated using a V engraving bit, but I can't visualise the finished lettering size/cut width. And no, I don't know exactly what lettering size I shall be using, but something of the order of 3-4mm character height (smallest letters) sounds about right. It also seems to depend on whether it's a 3- or 5-layer laminate because that changes the cut depth. Too many variables...
    Or I could use something like a 1mm flat-ended cutter?
    Anyone done this kind of work before and can offer some useful comments? I shall probably end up doing a number of trial cuts to see what it looks like anyway, but I'm about to order a few more cutters and I'm not sure what to go for.
    Thanks!
    Don't go above 20 degrees if you are doing 3 to 4mm high letters or they will finish up too fat and out of proportion.
    A 1mm flat ended cutter will about wipe out any letters with islands such as A, B, R etc.
    John S -
  1. Traffolyte where to buy?
    By IanParkin in forum Marketplace Discussion
    Last Post: 06-02-2020, 02:42 PM
  2. Eco Cast Plate or similar - Tolerances
    By jamesgates1000 in forum Metalwork Discussion
    Last Post: 02-04-2016, 02:03 PM
  3. Replies: 0
    Last Post: 11-05-2015, 03:27 PM
  4. WANTED: Wanted, Roland MDX 40 or similar
    By tommy1 in forum Items Wanted
    Last Post: 29-01-2015, 05:02 PM
  5. Corian and similar products
    By Fivetide in forum General Discussion
    Last Post: 20-10-2012, 03:36 PM
