06-12-2016 #4
Hi Rob,
First don't get too hung up on the Bob cheap or Expensive they all do the same Job which is providing an easy way to connect to the Pulse device. They don't actually do much more than pass signals thru and thou not recommended you don't actually need one at all.
You could connect directly to the parallel port cable but it doesn't provide any isolation to the PC so not recommended as could damage the PC if anything goes wrong.
The Pulse device in your case would be the PC parallel port which needs Motion control software like Mach3/4 which provide Parallel port Driver which interfaces with the PC.
So put simply you need Motion control software like Mach3/4 or LinxCNC.
In your Case I suggest using LinxCNC as it's free and can be run directly from Boot CD ( I think.? I'm not into linx others will correct me if wrong).
To run Machine the process goes.
Control software >>>Pulse Device(parallelport)>>>BOB (optional) >>>Motor Drive>>>Motor.
Why can't you install Mach3.? is it because using 64Bit PC.?
BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
By MikeyC38 in forum DIY Router Build LogsReplies: 74Last Post: 16-06-2018, 11:29 PM -
Fixed Gantry small precision begineer project advice
By yasu in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 17-10-2016, 07:14 PM -
Fixed z axis to gantry design
By Lachlan in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 20-10-2015, 09:50 PM -
Driving the gantry on Z axis?
By Skipsoaring in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 11-06-2015, 09:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM
