07-12-2016 #9
Possibly because of the PCI. It's very common for modern PC's to only supply 3.6V. However this is BAD NEWS for CNC and you need close to 5v to work correctly.
With 3.6V you will have trouble because there isn't difference between HIGH and LOW.?
When I said 0v and 5V I actually should have also said LOW & HIGH because that what really matters to CNC. LOW is anything from 0v to 2.5v HIGH is anything thing from 3.1 to 5V.
So with only 3.6v there not enough difference between Hi - Low signals and just slight difference or drop in voltage can cause missed steps and all sorts of strange happenings.
Only letters could put after my name are "NFC" or "CFS" but Hope that helps expalin little more.Last edited by JAZZCNC; 07-12-2016 at 08:27 PM.
BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
By MikeyC38 in forum DIY Router Build LogsReplies: 74Last Post: 16-06-2018, 11:29 PM -
Fixed Gantry small precision begineer project advice
By yasu in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 17-10-2016, 07:14 PM -
Fixed z axis to gantry design
By Lachlan in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 20-10-2015, 09:50 PM -
Driving the gantry on Z axis?
By Skipsoaring in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 11-06-2015, 09:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM
