  1. #7
    Quote Originally Posted by Peter Dow View Post
    It's like if I tell you "the width of a rectangle is to be 100% and the length 130%".
    Fine but before you can cut the rectangle from a sheet you need to know what length 100% is to be in mm.
    Now you explain it it makes no sense at all.
    What about needing a near zero tool diameter?
    This code kind of works for a single tile,
    (CNC program to cut Trispokedovetiles by Peter Dow.)
    (© Peter Dow. Caution - no warranty! Use at your discretion.)
    (CIRCLE % = 118%)
    (HEXAGON Length = 20 mm)
    (Number of Rows = 1)
    (Number of Tiles per row = 1)
    (CNC Code BASIC)
    G00 X6.34 Y90.00 (Fast traverse)
    M22 (start cutting)
    G4 P100 (dwell 100 milliseconds)
    G01 X6.34 Y88.20 (Linear Feed Traverse)
    G03 X16.56 Y94.10 I0.00 J11.80 (Arc interpolation)
    G01 X15.00 Y95.00 (Linear Feed Traverse)
    G01 X15.00 Y96.80 (Linear Feed Traverse)
    G02 X25.22 Y90.90 I0.00 J-11.80 (Arc interpolation)
    G01 X23.66 Y90.00 (Linear Feed Traverse)
    G01 X22.10 Y90.90 (Linear Feed Traverse)
    G03 X22.10 Y79.10 I10.22 J-5.90 (Arc interpolation)
    G01 X23.66 Y80.00 (Linear Feed Traverse)
    G01 X25.22 Y79.10 (Linear Feed Traverse)
    G02 X15.00 Y73.20 I-10.22 J5.90 (Arc interpolation)
    G01 X15.00 Y75.00 (Linear Feed Traverse)
    G01 X16.56 Y75.90 (Linear Feed Traverse)
    G03 X6.34 Y81.80 I-10.22 J-5.90 (Arc interpolation)
    G01 X6.34 Y80.00 (Linear Feed Traverse)
    G01 X4.78 Y79.10 (Linear Feed Traverse)
    G02 X4.78 Y90.90 I10.22 J5.90 (Arc interpolation)
    G01 X6.34 Y90.00 (Linear Feed Traverse)
    M00 (Stop cutting)
    G00 X0.00 Y100.00 (Fast traverse)
    M30 (Program End)
    except that the inside corners will have the radius of the cutter so the square outside corners will not fit together with them.
    EDIT- yes, probably good for a laser cutter which uses G-Code, but the paths will not work for rotary tool machines because square outside corners will not fit radius inside corners
  2. The Following User Says Thank You to magicniner For This Useful Post:
  1. A little bit of G code help please!
    By njhussey in forum Programmers Corner
    Last Post: 16-11-2015, 03:36 PM
  2. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 11:21 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  4. Spoke to some timing belt companies, intersting stuff........
    By psiron in forum Belt Drive, Pulleys & Timing
    Last Post: 23-09-2010, 03:51 AM
  5. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 11:39 AM
