Thread: Next stage is Plasma add on...
hi, iv two micro swithes on my z axis.top is machine home..bottom switch on slide is probe.g31 a very kind fella off the forum set up sheet cam to put the gcode into anything it post process's.........
thc ...havent a clue, im using a proma sd and struggling to get it working well....
can let you know how my 6 core cable is wired......
cheers
08-03-2017 #2
Hello Warwick...
The six cores i have wired up with the full 6/7 cores inc ground so same as you, i have all avenues covered.
Just the gcode and scripts is what i am struggling with.
Scoured the internet and cant find a dummies guide to floating heads etc as they all have different pin out names etc.
The proma you have, has quite a few explanations online with pictures but mine has none or very few with minimal explanation.
I would like a schematic of someone else's to scrutinise and once i have mine working, i will post mine on line with pictures for other people to look at as a picture tells a great story if you know what i mean.
I will keep experimenting untill i get the thing working....LOL
Cheers Tommy
08-03-2017 #3
its a very lonely place is the plasma section on any forum!!!!!`
the web is a nightmare for conflicting thoughts and nobody really posts the outcome of all the problems you are going through....
ill sort out the pins i have used and let you know.....
08-03-2017 #4
Many thanks Warwick
Do you have yours set to spindle, thc on thc up thc down etc etc as these are all the scenarios i am looking at and everyone seems to have a different solution but if you have a hypertherm 45 at least we have this in common...
As usual sorry about all questions but as you have experienced, it is a pain in the butt and frustrating.....i.e so close yet so far away from a fully working machine.
Thanks Tommy
09-03-2017 #5
hi, im using a mill screen at the moment and mine is indeed on spindle......my plasma screen set just crashed alot and caused problems, i think that i need to reinstall mach ..
on the mill screen im not getting a torch ok signal so my proma thc isnt working at all,which isnt a bad thing from the performace iv had off the dam thing....
may have another go at getting it running tommorow...............
oh and just to kick you a little more while your down!!!! ya compressor needs to be a beast...iv got a brand new italian cheap 12cfm compressor and when cutting 200mm tall letters i was getting one and a half letters before i had to feed hold mach and let the comp catch up........
cheers woz
09-03-2017 #6
Skiprat, I'm using the Purelogic Ethernet THC and BOB and Hypertherm 45 on my table. I don't visit here very often, but if you drop me a line by email I'll see if I can help.
[email protected]Last edited by AndrewMawson; 09-03-2017 at 10:13 AM.
10-03-2017 #7
Hello Warwick
I bought a 14cfm compressor off ebay from a fellow just down the road as spare or repair.
Got it home and it wouldnt pump passed about 50psi.......so i cleaned it up and tested the motor which was okay.....still wouldnt work ..
Changed the oil in the compressor which was black as black can be and away she went....never flawed since.
Basically i got a very cheap belt driven 14cfm compressor and an oil change done the trick.
Upto now, its powered my whole mancave no problems.
Cheers TommyLast edited by Skiprat; 10-03-2017 at 05:54 PM.
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
RFQ: Plasma job...
By Boscoe in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-09-2013, 08:43 PM -
My first CNC plasma
By Walterronny in forum DIY Plasma Build LogsReplies: 30Last Post: 20-02-2013, 02:13 AM -
plasma cad
By jamied in forum Computer SoftwareReplies: 6Last Post: 20-08-2010, 03:33 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
