  1. #6
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,957. Received thanks 366 times, giving thanks to others 8 times.
    In VR Milling, open the offset window (second icon from left at bottom of screen), then click on Work Offsets.
    Either jog to where you'd like X0 Y0 to be, then click the X and Y zero buttons, or if you're touching of an edge, use the calculator buttons below that to allow for the cutter/touch tool diameter.
    If you just want X0 Y0 to be front left, then jog the table until you hit the soft limits, and click the zero buttons.
    You can create and save plenty work offsets (I'm not sure if there is a limit on the number you can have), and it's just a case of selecting the offset you'd like to use, then clicking Activate.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. mach 3 scaling issue
    By terry1956 in forum Artsoft Mach (3 & 4)
    Last Post: 01-02-2019, 11:32 AM
  2. Syil X4 Plus - E-stop issue
    By Keith-h in forum Milling Machines, Builds & Conversions
    Last Post: 03-12-2016, 05:53 PM
  3. Arc movement issue
    By lukecnc2012 in forum Metalwork Discussion
    Last Post: 09-08-2015, 07:15 PM
  4. THC Setting Issue?
    Last Post: 17-10-2014, 07:53 AM
  5. Ref all home issue? A hand would be great just here!
    By suesi34e in forum Artsoft Mach (3 & 4)
    Last Post: 24-09-2014, 09:54 PM
