[QUOTE=m_c;86159]If it's windows based, then it should be VR Milling 2 or 5. Prior to that, I'm not sure of the name.
Although for simplicity having machine zero at the front left corner of the table makes sense, as then all travel is in a positive direction.
Thats what we expected as well but but the workpiece appears to be in the in the negative coordinates area which we cannot fathom out. We have looked at the information in the manual multiple times but are still scratching our heads!
Yes it is VR Milling 5 that we are using.
Im sure we will work it out eventually.
Thanks for trying to help, much appreciated :)Last edited by camhguh; 09-12-2016 at 06:17 PM.
10-12-2016 #2
In VR Milling, open the offset window (second icon from left at bottom of screen), then click on Work Offsets.
Either jog to where you'd like X0 Y0 to be, then click the X and Y zero buttons, or if you're touching of an edge, use the calculator buttons below that to allow for the cutter/touch tool diameter.
If you just want X0 Y0 to be front left, then jog the table until you hit the soft limits, and click the zero buttons.
You can create and save plenty work offsets (I'm not sure if there is a limit on the number you can have), and it's just a case of selecting the offset you'd like to use, then clicking Activate.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
mach 3 scaling issue
By terry1956 in forum Artsoft Mach (3 & 4)Replies: 22Last Post: 01-02-2019, 11:32 AM -
Syil X4 Plus - E-stop issue
By Keith-h in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 03-12-2016, 05:53 PM -
Arc movement issue
By lukecnc2012 in forum Metalwork DiscussionReplies: 4Last Post: 09-08-2015, 07:15 PM -
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Ref all home issue? A hand would be great just here!
By suesi34e in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 24-09-2014, 09:54 PM
