I normally read everything you write, Jonathan, with considerable interest and intent to learn; however, the above is not sound advice : Most designs would work on a IF=10-20mA with an IF(max) of 30mA or so - and so limited ability to increase the current (and therefore the emitted optical energy) within the constraints of the device; some (though by no means all) manufacture's datasheets will provide a peak IF rating given explicit constraints (e.g. 100mA at <10% duty-cycle with a pulse-width < 1ms), unless the OP is designing within the limits of the LED datasheet then exceeding the maximum rating of the device will, in all probability, reduce the reliability of the device and result in premature failure. You're also suggesting something that would cause significant current spikes on the driving system, which at reasonably high frequencies could cause EMC issues and possibly problems with the drive system. It's a design, designed to fail.
What the OP did with the pulse-stretcher is a well-engineered solution to his problem (though I'd do it differently!)Last edited by Doddy; 01-01-2017 at 06:41 PM.
01-01-2017 #2
Fair enough, I didn't think this one through - the signal should at least first be buffered (as the OP did) as we don't know the drive capabilities of the BOB and wouldn't want to adversely affect the signals to the driver optocouplers. Even so, as you say, there is a chance of the high di/dt causing issues elsewhere.
If obtaining the required brightness with any method requires operating above the LED pulse current rating constraints, then my proposal is moot. Although I would question how much the reliability matters here - after all the LEDs are just a neat accessory to the machine.Last edited by Jonathan; 01-01-2017 at 07:17 PM. Reason: grammar
Everything in one box (electrical)
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-12-2014, 11:11 PM -
FREE software for electrical schematics...
By birchy in forum Computer SoftwareReplies: 4Last Post: 15-12-2012, 05:29 PM -
Tutorials - From a drawing to a cutting example
By luke11cnc in forum Computer SoftwareReplies: 11Last Post: 25-09-2011, 11:19 PM -
Parker Digiplan schematics
By GT390 in forum General ElectronicsReplies: 1Last Post: 01-01-2011, 03:52 PM -
drawing to g-code
By ptjw7uk in forum Programmers CornerReplies: 12Last Post: 21-06-2009, 12:49 AM
