    Hi all,
    i'm new to the forum so excuse me if this post is in a wrong place.
    So here is my problem:
    I'm looking for a decent material to use for my DIY CNC router cutting bed (working area of 800x480mm). I need it to resist moisture as my router is in a garage that gets really damp during winter, and my current bed (plywood + mdf on top) expands and contracts like crazy.. I do a lot of V carving so a flat bed is a must.
    So at the moment I'm considering 20mm thick acrylic or 20mm HDPE sheet. I'm looking to spend up to £100 if possible. The entire bed size is 1100x620mm.
    So what do you guys think I should do? I just need a material that will resist moisture and bending.
    CHeers, Kamil
    There is a sign material called Foamex, I use a 19mm thick sheet, you can drill and cut it like MDF, but it's moisture resistant as it's plastic, it's nothing like perspex btw
    Martin
    Thanks Maxakarudy,
    Is it also a rigid material that won't deflect much while cutting?
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by mondrota View Post
    Thanks Maxakarudy,
    You will need something that you can drill and tap into as well.
    Yep,
    I have an industrial router, that's what most sacrificial beds are made of
    Ok, so I have 3 options now. I checked this foamex on ebay and it is much cheaper. I can drill holes and glue in t nuts at the bottom. I'm just a bit concerned about the rigidity of this material. It is a light foam material after all..
    19mm is very rigid, find a local sign company, they might have some to show you and could get you a sheet, Ebay is way too expensive
    How about Rigid PVC BLACK PLATE/SHEET 1520mm x 1300mm X 25mm THICK
    ebay item number: 152320149415
    Machineable, tappable, solid!
    A bit big for your purpose though? Maybe he would cut it??
    Thanks for all your input, I'll see how I get on and will keep you informed.
    I've been looking for the trespa Athlon stuff, I was quoted £90 plus VAT for a bloody off cut 600x400.
  1. CNC Router V1.0 (For Cutting Multiple Materials)
    By biketrialsdave in forum Gantry/Router Machines & Building
    Last Post: 05-08-2017, 03:37 PM
  2. Mini-Mill / Router - Cutting Fluid??
    By Davek0974 in forum Milling Machines, Builds & Conversions
    Last Post: 23-02-2016, 03:19 PM
  3. aluminium profile for cutting bed of router
  4. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
