    Still looking around :-x
    Measured the angle and although it might not be dead accurate, it reads 21 degrees.
    (Se Attached sketch)
Name:	Easychange toolholder angle.jpg
    I just hope Coventry feedback next week will tell me something...
    I've measured one of my Coventry Easy Change at 20 degrees
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Standard BT tapers are 7/24, which going by my calculation, works out at 16.26 degrees.
    I've measured Coventry Easy Change and BT30 for comparison/reference with a Moore & Wright Angle Thingy, here's the photos -
    I used BT30 because it's the "Taper Which It Definitely Isn't" which keeps getting rolled out here, it mystifies me and I was tempted to use a MT3 taper, but I'll go with the flow ;-)
ID:	20045   Click image for larger version.
  5. #15
    It really wouldn't surprise me if Boxford used a custom taper and holder design, just so you had to buy holders from them.
  6. #16
    Knowing a change in diameter over a fixed height it's a really easy bit of fag packet sketchery and school trigonometry to calculate the taper angle -
    Sine - Opposite/Hypotenuse
    Cosine - Adjacent/Hypotenuse
    Tangent - Opposite/Adjacent
    Do they still teach the basics at school? I meet so many people who don't seem familiar with them I do wonder,
    - Nick
  7. #17
    This is why i suspect the tool holders to be Coventry.
    My measurement was not accurate holding 2 steel rulers along each side and then measure With a School Plastic 180 Degree Protractor.
  8. #18
    I think Boxford and Coventry used to collaborate previously(at least) on toolholders.
    I seem to remember a chap talking about some Coventry toolholders for his VMC190, and i think it`s the same toolholder.
    Still havent got any answer from Neville at Coventry yet though.
  9. #19
    - Nick
    This is basic Math Nick, but the Challenge is to measure 100% correct top diameter on the taper and correct distance in between(the taper top i slightly rounded).
    Tryed to improve my measurements and got lower dia at 31,61, top dia at 20,9 and length at 30. This gives a Cone angle α = 20.24° = 20°14' , taper 35.7%.
    This is definately no standard taper in my opinion...
  10. #20
    Quote Originally Posted by Proteus View Post
    Your dimensions are almost exactly what I get off the Coventry Easy Change if I try to measure where you have using digital calipers.
    Because of the problems measuring the top edge of a frustum with calipers I chose to measure the OD in two places where an easily measured OD is available, at the bottom edge of the taper and the top edge of the groove, with a micrometer then measure the vertical distance between the two with a vernier, that gives me a calculated angle of 10.02 degrees. (Once I'd downloaded a decent calculator with inverse functions to my phone - what's the use of sine without arcsine Mr Samsung!)
    If you super-glued your two steel rules together in alignment with the taper you could draw a nice big triangle on a piece of A4 and measure/calculate the angle ;-)
    - Nick
  1. Boxford VMC300 conversion & parts. Help really needed.
    By Proteus in forum Boxford Vertical Mills
    Last Post: 13-09-2016, 02:13 PM
  2. How to remove coventry easychange chuck/toolholder
    By Rabs in forum Milling Machines, Builds & Conversions
    Last Post: 06-11-2015, 07:08 PM
  3. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. A question
    By bodgeitandscarper in forum Gantry/Router Machines & Building
    Last Post: 02-12-2009, 08:30 AM
