Thread: VMC300 Toolholder question
This is basic Math Nick, but the Challenge is to measure 100% correct top diameter on the taper and correct distance in between(the taper top i slightly rounded).
Tryed to improve my measurements and got lower dia at 31,61, top dia at 20,9 and length at 30. This gives a Cone angle α = 20.24° = 20°14' , taper 35.7%.
This is definately no standard taper in my opinion...
20-12-2016 #2
Your dimensions are almost exactly what I get off the Coventry Easy Change if I try to measure where you have using digital calipers.
Because of the problems measuring the top edge of a frustum with calipers I chose to measure the OD in two places where an easily measured OD is available, at the bottom edge of the taper and the top edge of the groove, with a micrometer then measure the vertical distance between the two with a vernier, that gives me a calculated angle of 10.02 degrees. (Once I'd downloaded a decent calculator with inverse functions to my phone - what's the use of sine without arcsine Mr Samsung!)
If you super-glued your two steel rules together in alignment with the taper you could draw a nice big triangle on a piece of A4 and measure/calculate the angle ;-)
20-12-2016 #3
I am not into math but the way I see it is that you could put the tool holder into a known dia. hole in a piece of thin stock to measure the top di. then it would be easy to measure the distance to the bottom. Just my 2p worth.
Boxford VMC300 conversion & parts. Help really needed.
By Proteus in forum Boxford Vertical MillsReplies: 0Last Post: 13-09-2016, 02:13 PM -
How to remove coventry easychange chuck/toolholder
By Rabs in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 06-11-2015, 07:08 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
A question
By bodgeitandscarper in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-12-2009, 08:30 AM
