Thread: How hard is it to weld a frame?
I've never welded before but watching videos makes me want to have ago but its the warping on the rails section that scares me, I don't really care if the weld doesn't look pretty as long as its a strong weld. I might just try a bolt together frame but at the same time I do really want to have ago at welding too.
15-12-2016 #2
you will still need to weld a bolt together frame......with mig you can have a nice looking weld and it can still be a bad weld......if youve got access to a mig get some scrap and have a play.DONT LOOK AT THE PRITTY BLUE LIGHT without a mask.....its a hectic first expieriance..pull the trigger youve got wire pushing out of the torch,alot of hot balls of metal dropping down your sock, not being able to see enough through the mask so on and so forth.....warped rails is the least of your issues......learning to weld will open up all sorts of interesting avanues and is a skill well worth having...but you arnt going to buy some steel and weld a frame on your first go with any welder
15-12-2016 #3
Thanks warwick, i am buying a mig welder but gasless so will be spending sometime practicing and will be posting results up before i start on the frame to see what you guys think
16-12-2016 #4
Dont buy gassless
Buy a normal one and a CO bottle from some bar for next to nothing. Together with the regulator. Thats how i started. Of course i was not thinking like you and bought 250AMP welder which i am very happy with. It cost me around 350 euro only from ebay. Its working like a champ.
16-12-2016 #5
Thanks mate, I was told I need a licence for gas but if I don't then I would go gas
16-12-2016 #6
Reefy,
what country you in? In the UK there is no need for license to get Argon or CO2 for welding. There is of course a cost associated with the use of the gas canisters. Again in the UK you can look for rental free gas, where you get charge a deposit and refill charge as opposed to having to sign up to a yearly contract.https://emvioeng.com
16-12-2016 #7
I welded my router frame up using a 90A SIP stick welder off ebay, as well as the professional MIG welders I had access to at my old work. If you cut the metal accurately, take your time positioning and tacking and have a large hammer and a grinding disc/cutting disc along with lots of patience then you can easily weld up an accurate frame, especially if you're planning on using epoxy for levelling. Secret is not to put too much heat into any one bit, so tack then move on to a bit on the opposite side and tack etc. leaving plenty of time for things to cool down.
Tig weld rack and pinion to cnc plasma frame?
By warwick in forum Plasma Table MachinesReplies: 19Last Post: 10-12-2016, 07:39 PM -
Turning hard materials
By Harry Hills in forum Metalwork DiscussionReplies: 16Last Post: 07-02-2016, 04:49 PM -
Best place for hard stops?
By mitchejc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-11-2014, 06:39 AM -
RFQ: Why is it so hard...
By ktc in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-08-2013, 08:05 PM -
RFQ: Hard colour anodising
By Mixster in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-03-2013, 10:58 PM
