Page 6 of 6 FirstFirst ... 456
  1. #51
    I had a couple left behind by an electrician after some work in the house which I have used on my own router and like you, I crimped on ferrules to stranded wires. They seem very effective, slightly larger than the equivalent choc block but easier to wire. I just left mine floating in one of the plastic boxes I use as junction boxes (which I was buying from Maplin but now 3d print).
    Wago do junction boxes, you might like to adapt your 3D prints accordingly http://www.screwfix.com/p/wago-abox-...Fa237QodaegHvA
  2. #52
    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Custom printed boxes including guides for the Wago connectors, which could be tweaked to suit whatever combination of connector sizes needed. Sounds like a neat idea - thanks for the pointer, Rob.
  3. #53
    You could also print these https://www.tlc-direct.co.uk/Products/WA332.html
  4. #54
    Now those do look like a good idea, and cheap as well. Look much easier to use than screwdown DIN terminals which are a pain to use in a crowded control box.
  1. Stepper problem
    By eurikain in forum Stepper & Servo Motors
    Last Post: 19-12-2015, 03:25 PM
  2. Problem with my Z axis
    By mikem in forum Stepper & Servo Motors
    Last Post: 03-11-2015, 11:52 PM
  3. Removing stepper motor problem from sherline mill
    By Neeps in forum Sherline Mills
    Last Post: 12-04-2015, 12:09 AM
  4. Stepper motors - problem
    By dudz in forum Stepper & Servo Motors
    Last Post: 13-02-2013, 07:07 PM
  5. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
