02-02-2017 #22
Thanks Graeme, i will see if i can find the data sheet online.
I would say both chips have definately failed, the black plastic has popped in both cases and in the case of this particular chip i opened up the contol box fairly quickly and the place where it had popped was still melted and gooey. But like you say whether this failure resulted in blowing the track or wwhether the track blew as a result is a different matter. I will admit i was not particularly thorough last time i replaced the chip in checking the back of the pcb, i just tested the socket pins were gripping ok and only quickly scanned the back so it is possible that this crack was there prior to replacing the chip.
This failure did take out an 8 amp slow blow fuse on the power supply tooLast edited by howser37; 02-02-2017 at 04:28 PM.
Stepper problem
By eurikain in forum Stepper & Servo MotorsReplies: 32Last Post: 19-12-2015, 03:25 PM -
Problem with my Z axis
By mikem in forum Stepper & Servo MotorsReplies: 4Last Post: 03-11-2015, 11:52 PM -
Removing stepper motor problem from sherline mill
By Neeps in forum Sherline MillsReplies: 1Last Post: 12-04-2015, 12:09 AM -
Stepper motors - problem
By dudz in forum Stepper & Servo MotorsReplies: 7Last Post: 13-02-2013, 07:07 PM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM
