    I had a couple left behind by an electrician after some work in the house which I have used on my own router and like you, I crimped on ferrules to stranded wires. They seem very effective, slightly larger than the equivalent choc block but easier to wire. I just left mine floating in one of the plastic boxes I use as junction boxes (which I was buying from Maplin but now 3d print).
    Wago do junction boxes, you might like to adapt your 3D prints accordingly http://www.screwfix.com/p/wago-abox-...Fa237QodaegHvA
    Custom printed boxes including guides for the Wago connectors, which could be tweaked to suit whatever combination of connector sizes needed. Sounds like a neat idea - thanks for the pointer, Rob.
    You could also print these https://www.tlc-direct.co.uk/Products/WA332.html
    Now those do look like a good idea, and cheap as well. Look much easier to use than screwdown DIN terminals which are a pain to use in a crowded control box.
  1. Stepper problem
    By eurikain in forum Stepper & Servo Motors
    Last Post: 19-12-2015, 03:25 PM
  2. Problem with my Z axis
    By mikem in forum Stepper & Servo Motors
    Last Post: 03-11-2015, 11:52 PM
  3. Removing stepper motor problem from sherline mill
    By Neeps in forum Sherline Mills
    Last Post: 12-04-2015, 12:09 AM
  4. Stepper motors - problem
    By dudz in forum Stepper & Servo Motors
    Last Post: 13-02-2013, 07:07 PM
  5. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
