Page 2 of 2 FirstFirst 12
    Looks good, I'd beef up the bed as it looks weak compared to the rest of your machine ��
ID:	20088Click image for larger version.
    Added T6 20mm plate:)
    Robin think you better explain because even I can't tell where your coming from with this statement.? If your meaning what I think where is going to put the ballscrew.?
    I can't explain, I should probably shut up, it just looks unfinished. If the router moved back towards the gantry it would look better. If the lower Z axis bearings were at the bottom of the gantry it would look better. If the bed bearings were under the gantry so it didn't depend on verticals screwed to horizontals I would be rubbing my hands together in glee and shouting whoopy do!
  3. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  4. #13
    Robin do appreciate your comments, so far I managed to skim 10mm by putting spindle closer to the plate.
    Problem is that I should ask first and fabricate later. I am seating on it now - previous correction was easier to do.
    I will put X axis bearing on top and bottom of the gantry - saving a lot of distance but sacrifice stiffens (extra 50mm taller legs)
    Regard the bed bearings as you see from current design they are in between spindle center point - so perfect position (this will moved towards gantry later).
  5. #14
ID:	20090Click image for larger version.
    now Z rails left - this will complicate fabrication, thinking now to use alloy plate and make kind of box design
  6. #15
    some modification made to design - thanks Rob
ID:	20162Click image for larger version.
ID:	20163Click image for larger version.
ID:	20164Click image for larger version.
ID:	20165Click image for larger version.
ID:	20167Click image for larger version.
ID:	20168Click image for larger version.
Name:	Spindle plate mk2.JPG
ID:	20169Click image for larger version.
Name:	Z plate mk2.2.JPG
    I managed to short less than 50mm in overhang - hope will be worth it.
  1. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  2. FOR SALE: fixed gantry router/mill up for grabs
    By dazza in forum Items For Sale
    Last Post: 12-03-2015, 11:15 PM
  3. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
