    I'm so not surprised, this demonstrates exactly what has kept me from even considering cloud based software for anything I might want to see when I want to see it and not when the vendor can let me see it.
    A second issue for me is updates applied when convenient for the vendor, if my CAD/CAM isn't broke I don't fix it ;-)
    - Nick
    I am hugely tempted to try Fusion 360 for die sinking even if it is a bit buggy. Apparently I can rent it for £30 a month when I need it, how good is that?
    I am not hugely clear about drawing stuff with it, is it very different to AutoCAD? Thought I would give the demo a try over Xmas.
    The tool paths look really neat and in control, if you know what I mean?
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Fusion 360 is free for hobby use just register and you are good to go. I use Autocad but only 2D so can't comment but 360 is very powerful and a steep learning curve but worth thee trouble
    The big difference between AutoCAD and Fusion 360 is that F360 is parametric. This takes some getting used to but once you are there it feels very odd and restrictive going back to ACAD.
    Parametric means you can loosely draw something and add dimensions to it. You can then edit the dimensions and the drawing will refresh automatically. You can also add various constraints to do the same thing.
    In AutoCAD you have to edit the lines themselves and move / edit the points around. Instead of that once you get used to thinking of the lines as a framework which contains rules to define the drawing it makes CAD much quicker and very powerful.
    - Nick
    More importantly if it is fixed don't break it.
    It's very, very different.
    Much closer to Solidworks than it is to AutoCAD. For most things, you start with sketches, and then extrude them. Just be sure to follow this rule:
    http://forums.autodesk.com/t5/post-y...2/td-p/6581749
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Fusion 360 - best approach?
    By routercnc in forum Fusion 360
    Last Post: 18-06-2016, 07:49 AM
  2. Digitizing probe / Point cloud to mesh
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 07-09-2013, 10:03 PM
  3. 3D Printing Coming Along
    By Washout in forum 3D Printing Machines
    Last Post: 04-10-2012, 10:21 PM
  4. NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
    By Simon in forum New Member Introductions
    Last Post: 26-06-2011, 10:02 AM
  5. Super X1 conversion - CNC Fusion kit
    By bruce_miranda in forum Sieg Milling Machines
    Last Post: 19-09-2008, 01:43 PM
