    Are you just wanting to drilling holes or wanting to cut out shapes etc. As drilling could be done on a manual mill.
    A picture is worth a thousand words of what you are trying to achieve.
    Holes and shapes. But even getting holes right on my manual mill is tedeaous because it has no readouts and the backlash is terrible plus my lack of skill. I am looking to do production quantities on this machine to get it to pay for itself along with good fast prototyping.
    There will also be plenty of cutting down of potting boxes, the bigger they get the taller they get and this can become a problem as what I need are more like trays so the only thing I can do it to cut down existing boxes.
    Quote Originally Posted by SparkyLabs View Post
    That sounds like a job for a bandsaw with a suitable guide to get them within a couple of millimetres and a quick pass with the mill to finish ;-)
    Might pay to have a look at one of the blue A3 style laser cutters on Ebay for about £1500
    I used to mill boxes out for the division master style hand held controllers and one case too about 15 minutes with some rejects where the plastic had welded to the cutter and ruined the box.
    I now do these on the laser in about 2 minutes with no rejects
    John S -
    Do you have any links to the laser cutter. What are the limitations of laser if any ? I could of course end up cutting metal too. With plastic I am hoping that a nice sharp cutter not too much speed will prevent melthing. I've not had any problems hand milling with melting, just the positional accuracy that take so long to get right that it would not work for repeats.
    Well I am based from home so don't have room to set up a complete machine shop. I need a bit of a one size fits all machine, granted some jobs are not the most suited but if they can be carried out with no severe downsides then that is fine.
    I have a bandsaw that's just 24" tall with an 18" x 12" footprint that can be used on a Machine Mart bench grinder stand, it has a plethora of uses, all of which save time and some of which save material ;-)
    Well here and now I need to be able to first cut holes and slots and other shapes in the side of cast aluminium and ABS boxes. As I would not be able to afford any further machinery after that I'll have to use the mill for the box cutting down. Of course large quantities can be done by the box manufacrurer if I am not equiped.
    I would suggest that you try and contact some one in your area to see a mill working so you will have some idea as to what is involved before you start spending the hard earned dosh.
    I for one would be more than happy to show you if you are ever up here (Stockport)
  1. Thinking about new CAD / CAM
    By Tenson in forum CAD & CAM Software
    Last Post: 13-09-2015, 10:18 PM
  2. Thinking of buying/building machine for PCB milling
    By njh in forum Marketplace Discussion
    Last Post: 11-10-2013, 07:35 PM
  3. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
  4. router jumping position
    By johngoodrich in forum Linear & Rotary Motion
    Last Post: 23-09-2011, 06:31 PM
