Page 2 of 2 FirstFirst 12
    seems I have been shamed into it.
    Sorry for the crap photos, and after seeing how good some of that kit looks in other peoples garages I'm not sure I want to share my poor relation kit Click image for larger version.
ID:	20237Click image for larger version.
ID:	20234Click image for larger version.
ID:	20233Click image for larger version.
ID:	20236Click image for larger version.
ID:	20235Click image for larger version.
    Plan is to do a big clear out, put up new work bench, clear out old work bench and have lathe on the 2nd one, and control units/PC's on the shelf underneath (hopefully cables will reach!)
    Next will be welding up a few wheeled tables, one for the granite plate and one for the band saw so I can shift them round the workshop.
    Then I will plumb in the new air compressor into some semi perm lines, also adding in my new lights (LED panels) and sockets around the garage.
    Finally I plan to dramatically cut down on the stuff stored on shelves, and instead buy a few cheap steel tables, stack them on top of each other and secure together, create a lower skid on wheels that the lower table sits in, then use some cheap roofing sheet (painted steel) to turn them into large mobile cupboards - that way I have the same storage, but it can be moved round the garage unlike shelves - I plan to be doing CNC woodwork and CNC metal work and some motorcycle maintenance (on my own bike), so I need to be able to shift stuff about as my garage isn;t big enough for all three as permenant set ups - but I can temporarily block in equipment I don't need.
    I also added the only thing I have made on the novamill - it was a little computer game logo into a medallion for my little lad - just used some scrap galv steel sheet I had - dodgy work holding, but the vice crushed it and I dont have a sacrifical alu pallet etc yet - though it is on my list of things to make.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    There's clear floor space!
    Where do you find that?
    Chaz's Avatar
    Awesome, it can all be improved. I need to move Thor inside so the bit of space I have made will be lost but will need to manage somehow.
    If only we all had those dreams
  5. #15
    Got the hydrovane up and running before, it is so quiet compared to my old cheapy compressor. No where near as loud as a vacuum cleaner, maybe a similar volume to a.hair dryer. Made up with it.
  6. #16
    Little update video - will try to pull a series together over the coming months as I get more set up. This is my bandsaw cutting aluminium.
    https://youtu.be/dvb_iTOpJlI
  1. Workshop & Noise Help
    By kemo_2002 in forum Workshop & Equipment
    Last Post: 12-04-2014, 10:16 PM
  2. Replies: 1
    Last Post: 13-02-2014, 03:40 PM
  3. New Workshop
    By Washout in forum Workshop & Equipment
    Last Post: 26-12-2012, 10:22 PM
  4. Fly-through tour of my workshop
    By panofish in forum Workshop & Equipment
    Last Post: 06-05-2012, 07:13 AM
  5. Workspace or workshop?
    By mocha in forum Workshop & Equipment
    Last Post: 25-04-2012, 01:54 PM
