15-04-2012 #1
For members amusement some details and images of my newly (today) commissioned MK-2 CNC machine.
Details:
- Primary use: hardwood v-carving and associated 2D cutting.
- Effective working area: 800 x 500mm
- Designed max velocity: 1,800mm/min (typical v-carving 600-800mm/min)
- Removable raised MDF base to accommodate deeper work objects.
Main components:
- 80mm aluminium extrusion gantry (KJN) on 40mm steel frame (local stockist)
- Electrics: 4 Nema 23 motors (X-axis x 2) with 542 drivers and two 42v PSU (Zapp)
- Rail: X- & Y-axis 20mm supported (Zapp); Z-axis 20mm unsupported
- Ballscrew and bearings: 1605 (ebay Linearmotionbearing and smpart)
- MACH3
- {Very large floor mounted E-stop switch (a 'piece of cake' to install)}
To do:
- Fit limit switches
- Install dust extraction - dust shoe design.
- Select and fit water-cooled spindle.
- Modify to MK-2.1 - create larger working area - transfer X-axis components to Y-axis and puchase additional extrusion, supported rail and ballscrew for X-axis. Hopefully a quick win.
*** A gold star awarded for identifying which forum member's design this machine was based on.
And next - steel frame already constructed for MK-3 machine - sized for working 8' x 4' board.
Don't be too harsh - it's a hobby.
Karl
BUILD LOG: This is my first BUILD please help.
By DigiSoft in forum DIY Router Build LogsReplies: 60Last Post: 27-01-2016, 04:37 PM -
Add-on CNC build log
By bikepete in forum Milling Machines, Builds & ConversionsReplies: 23Last Post: 06-02-2013, 03:02 PM -
Build or buy?
By jonnydeen in forum Machine DiscussionReplies: 6Last Post: 13-05-2012, 11:01 PM -
Just a tip for anyone looking to build CNC
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-07-2010, 06:08 PM -
BUILD LOG: my build
By jonm in forum DIY Router Build LogsReplies: 54Last Post: 22-04-2010, 10:14 PM
