01-01-2017 #6
Thank you!
12k rpm is asking much, Chris @ LMS says it's good for about 10k rpm. Angular bearings are rated at 12k rpm, if you double up they drop to about 9600rpm and if you decide to fit a radial shaft seal their limit is a surface speed of 18m/s. At 40mm diameter (the lower part of the LMS spindle) that's about 8400rpm.
Still, my main concern is how much and by what means to preload the bearings. I hope I get to the bottom of this.
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Base design for new router
By cncgreg in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 31-08-2010, 03:35 PM -
NEW MEMBER: Manouchehr from small workshop
By Manouchehr in forum New Member IntroductionsReplies: 1Last Post: 22-08-2010, 10:20 AM
