01-01-2017 #8
Nice ideas, but i have serious doubts about using the 2.2kw spindle as a power source for this type of setup. The bearings are poor and won't take the constant side-load of a belt, torque at lower speeds is terrible as well. I looked into ATC stuff recently on my Bridgeport conversion and gave up as it was beyond difficult - I need an ATC that can handle 24k + but at those rpm's everything needs proper balancing which is beyond the home shop.
I would go for a BT30 spindle, definitely not R8 in any case.
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Base design for new router
By cncgreg in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 31-08-2010, 03:35 PM -
NEW MEMBER: Manouchehr from small workshop
By Manouchehr in forum New Member IntroductionsReplies: 1Last Post: 22-08-2010, 10:20 AM
