    If you can't source thick plate can you use plug welding through alternating patterns of drilled holes to laminate several thinner plates into a suitably rigid assembly?
    You might even get less resonance in a laminated assembly than a single plate?
    Just thinking out loud,
    - Nick
    Maybe take a look at www.clickmetal.co.uk and if you price up (its online, instant price) what you have bought before. T
    Ah ah they want £246 + vat for 920 x 700 x 20mm standard 6082-T6 plate which is last size I bought just before Xmas. Think I paid £187 inc vat for Ground tooling plate.
    Chaz's Avatar
    - Nick
    Not sure what Plug welding is but I had considered welding up a few layers of say 10mm to make up what I need. Thanks. Certainly an option.
    Chaz's Avatar
    Ah ah they want £246 + vat for 920 x 700 standard 6082-T6 plate which is last size I bought just before Xmas. Think I paid £187 inc vat for Ground tooling plate.
    Thanks, fair difference. I think we discussed this before but you 'local' doesnt really deliver outside of your area? The cost of transport for that plate, say £30 will still make it somewhat cheaper. Can you let me know who you buy from please?
    Thanks Jazz.
  5. #15
    If want to go the casting route give these lads ring for quote.
    http://www.smallcastings.co.uk/
  7. #16
    That came from ASC metals. Nearist to you is peterborough I think.
    http://www.ascmetalsgroup.com/
  9. #17
    Chaz's Avatar
    Do they cut into smaller sizes? I dont have tools to cut large sheets, part of the issue. What is the best option for something to cut required sizes from thickish plates (like 25mm)?
  10. #18
    A couple of 10mm plates welded as per Nick's recommendation and use 30/40mm square section on the edges for mounting your bearings or rails.Joining the plate is done by machining a pattern of holes in one of the plates you intend to join clean both matting faces and clamp them together then weld the inside the holes.
    Regards
    Mike
  11. #19
    Chaz,
    Plug welding is welding through a hole and "plugging it".
    Drill a pattern of holes diameter 2x thickness in one plate, clamp it to a second plate and weld through the holes in the first to the second plate and the hole walls, finishing by filling the holes then grinding flush.
    Add further plates in the same way until the desired thickness is achieved, you could optionally weld around the outside,
    - Nick
  12. #20
    Last time I did any work on heavy steel plate I had access to Oxy/Gas burning kit, the only thing I have now is my plasma cutter which is only rated for 13mm steel, I suspect you could rent a plasma cutter for a day from a tool hire outfit,
    - Nick
  1. Milling mild steel
    Last Post: 16-02-2014, 02:31 PM
  2. RFQ: Several mild steel parts
    By dudz in forum Projects, Jobs & Requests
    Last Post: 26-08-2013, 11:37 AM
  3. Replies: 25
    Last Post: 03-05-2013, 09:31 AM
  4. Cutting 1.6mm mild steel with a CNC machine?
    Last Post: 01-05-2012, 09:56 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
